RCU Forums - View Single Post - engine mounting question
Old 09-12-2003 | 02:26 PM
Hircflyer's Avatar
Hircflyer
Default RE: engine mounting question
You may be over priming the engine. Hopefully the tank is in the correct location in relationship to the carb sometimes that will cause the engine to flood prior to starting.
Try starting the engine without priming. If using a starter please ensure the engine turns easley it is very easy to bend the connecting rod trying to start a inverted flooded engine.
There is nothing wrong with getting a helper to hold the airplane upside down to assist in starting.
