RE: Welcome to Club SAITO !
Another nice to know in the knowledge sphere. Has any one considered using the throttle curve program in the Heli section of our new you beaut electronic radios. What we (some Vintagents / SAM 84) are experimenting with is setting up the engine (particularly on Duration models tat use slam aceleration) using the heli throtlle set up and then copying it to the applicable model. Experiments have indicated that the throttle is less likely to bog down (flooding with sudden throttle movement) and it gives a smoother more balanced response just as quick. You can use the linear or expo set up but this seems give better / smoother response. And my old mentor says it is a good imporvement for his arthritic hand, the throttle one. Will report back
