RCU Forums - View Single Post - 1/5.3 Horten 229
Old 12-05-2012, 06:13 PM
invertmast
My Feedback: (23)
invertmast's Avatar
Default RE: 1/5.3 Horten 229
DISASTER!!!!!!!!!!!
JUST KIDDING!
Here ya go...
bottom:
Inlet lips:
Top:
Looking in the inlet with the halves bolted back together:
The plug came out 99% perfect. There are only 2 little places about 1/4" long each where the inlet block-off plates are that where damaged (body filler chipped out). Otherwise, the plug is exactly like how it was before it was molded, which is great, cause now I can use it as a paint test piece lol
After the mold was split, we test fit the master templates. Granted no composite skin is layed up yet, but it told us the templates are pretty dang close to being perfect. Just a little fine tuning to do to them, and then we need do all the lightning holes, etc and they are done. But we can't do this till the skins are layed up and.
Carry through spars. These are 3/16" aircraft ply, and will have another 3/16" doubler around the tube tube sockets. The sockets will also be epoxied and glassed to these spars.
Here is a shot of the landing gear plate support structure. Again, all 3/16" aircraft ply. The Landing gear plate will be 3/16" ply as well and will probably have a layer of glass or carbon on one side. These parts will all be interlocking so they key together and the plate will slot into the ribs. This entire structure will also be over a carbon re-inforcement panel in the composite skins.
And then we sprayed some green paint on the top of the wings.. only 3oz used for both wing panels and elevons.. still need to paint the top of the flaps:
This Friday/Saturday I'm going to try and mold the canopy frame, main gear doors and the vacuum form canopy plug..
