RE: What should happen in a case like this And how do you go about forcing the Issue.
I have the Great Planes F-14 tomcat also, I fly it regularly. If you build another Tomcat put a bigger engine in that plane. Like you said it is a heavy bird. You need at least a 75 size motor in it. Trust me you will be glad you did. Stinger probably wouldn't have caught ya. Im sure with the 55ax it is way underpowered. I can't believe you get it off the ground with that motor.
