RCU Forums - View Single Post - Sebart Mythos 2mtr
Old 12-07-2012 | 02:55 PM
DAMBUSTER
Default RE: Sebart Mythos 2mtr
Hi,It seems the Mythos has the same fuz as both the Wind S Pro and the Composite version of that model. Both of those models,and by default the Mythos, have a problem with Stab incidence due to the anhedral which is not allowed for in the stab "spar" and anti-rotation pin positions in the fuselage. The problem is particularly bad in the Composite version which has more anhedral and thicker stab section.
These problems have been dealt with at length in the threads for the Wind S and Composite on this site.
You will need to determine the amount of anhedral to find which fix you need to apply.If the anhedral is as the Wind S then screwing the stab adjusters to their max (and maybe filing out a little ) will probably give what you need.If the anhedral is as the Composite then you need a more drastic fix (see threads!).
On the Wind/s I have built I have also installed wing adjusters,without these I don't see how you will get the set up you say,.....or does the Mythos have wing adjusters ?
Cheers Dambuster.
