RCU Forums - View Single Post - Seized Up Engine?
Old 12-08-2012 | 02:00 AM
ou2mame
Default RE: Seized Up Engine?
when you take the pull start off, make sure you are careful so that you don't undo the spring. try to pull it off with a screw driver on the back to hold the wheel that the string sits on, so that it doesn't go anywhere. there's also a small sprint that goes on the nut that connects to the wheel, so make sure you don't lose that too. just be careful with it cause that's a ***** to put back together. i've done it more than a few times, there's certainly an art to it lol...<div>
</div><div>but yeah.. you don't even have to take the engine out, you can just take the rear diff off to access the pull start. i find that that's sometimes easier, depending on what i'm doing.</div>
