RCU Forums - View Single Post - cant get 160 booster started
Old 12-08-2012 | 09:11 AM
SinCityJets
Default RE: cant get 160 booster started
Dr. Honda, we don't use an external thermo coupler. All internal.
Musky, what is your set up? What plane is it in? Are you using a bypass or thrust tube? You usually see this if the exhaust air is re-circing through the system. If you could post a pic of your install it would help diagnose.
Chad
