RE: German rear convoy light
Jerry,
I have to take my hat off to you the work you have done is increadable to say the least, if you can get 603’s in green then go for it all you then need to do is turn the glass tube in a lathe and using sand paper take the glaze off then using black paing give it a thin coat then coat in clear varnish this is all I have done the black paint while looking historicaly correct also tones down the glow of the LED’s, I may have to take your lead and use 603’s in my light so that I can have all 4 bulbs working.
