RCU Forums - View Single Post - FEJ Large Hawk
Old 12-09-2012 | 11:36 AM
Ali's Avatar
Ali
Default RE: FEJ Large Hawk
Completed wing with gear folded away. Note: Gear door fit. Pre fitted and hinged flaps with flap hinge fairings pre attached. I went with the Powerbox wire set for connection of the aileron and flap servos. ANyone who is not aware of this product and has planes with two or three servos in each wing... Should be. Its such a neat, quick, easy and solid way of hooking up servos at the field. No longer do you have to faff around matching servo plugs and fiddling with them to connect your plane up. One plug and your done. The smelted end means you can tug on the green plug with total confidence, and the fact they come with servo wires pre fitted means no hassle of soldering up the green MPX plugs with their tiny pins and meltable plastic bodies.
Also you can see the other half of the self aligning air connector... pre fitted of course !
You can also see the wing attachment. A 4mm bolt at the rear ( pre fitted to a captive nut inside the fuz ) The carbon rod at the front of the wing is glued to the wing and passes through an aluminium clamp which tightens up with a allen bolt from the underside.
