RCU Forums - View Single Post - FEJ Large Hawk
Old 12-09-2012 | 11:45 AM
Ali's Avatar
Ali
Default RE: FEJ Large Hawk
Servo hooked up to the pre supplied pushrod. Only difference being that I used a 3mm Clevis at the servo end rather than the heavy duty pin through clevis that FEJ supply. The FEJ item is beter as its far heavier duty, and there is no way of the pin breaking ( as with a conventional clevis ) It's kist that the slot at the servo end differs slightly to the control surface end and is slightly too thin for the JR super servo horns which I use. I could have skimmed a bit off the horn, but didnt like that idea. In retrospect, I should have filled the slot in the clevis slightly.. Doh!
The alu 90 deg servo mount brakets were pre supplied.
