After owning the fifth scale CARF Hawk (originally scaled down from the Skygate) for a few years I always said the only way it could be better would be to have a bigger one. With all the work involved on the Boomerang side I would never have had time to build the Skygate kit version so how cool is it that CARF have finally got the ARF version available ! Of course it would be sensible as Boomerang sell CARF models to have one to try
My Hawk arrived recently and I haven't had a chance to look at it properly but today I finally had a chance to hang the kit together and boy am I impressed ! Fantastic fit and finish, all the original detail of the Skygate model and very ARF. Nose gear doors are hinged and fitted, main gear doors same thing but not fitted for ease of transport. Everything hinged (scale), control horns in the surfaces. CARF have also taken to blending the seams on the fuselage which is great. Everything looks to be usual CARF style, superbly engineered, very strong and very light. I have weighed everything going in the model and I see no reason why this shouldn't be an under 20kg dry / 25kg wet model with a 180 size turbine. Legend has it that these babies fly better with a bit of weight in them but the great thing is you can have the choice to add weight if you want whereas taking it out isn't quite so easy.
Im hoping to get on to the assembly over the next few weeks but from what I have seen so far it shouldn't take too long. Here are some pics for starters..
