RCU Forums - View Single Post - How do I remove the head from a YS 140L engine
Old 12-09-2012 | 01:00 PM
tande
My Feedback: (48)
Default RE: How do I remove the head from a YS 140L engine
ORIGINAL: crashlander
Hi guys:
I want to remove the head from my YS 140L engine as I do not have compression. I am suspecting one of the valves is stuck.
Thanks.
Orlando
You will need to be more detailed in your question.....it's bolted down with five bolts....unbolt in a criss/cross pattern, you will need to remove the rocker/arm/shaft to access two of the bolts......
