RCU Forums - View Single Post - Clark electronics TK20
Old 12-09-2012 | 10:49 PM
  #301
B.A.D.A.S.S.Force's Avatar
B.A.D.A.S.S.Force
Default RE: Clark electronics TK20
ORIGINAL: clarkmodel
Thanks for the summary, Craig.
One thing need be added here is that h/w modification is required if you need Gun Elevation Servo Port., unsolder one resistor and resolder it to another pad.
Regards,
Clark
So a resistor on the TK22 board will have to be removed from one place on the board & soldered to another area before the gun elevation servo port can be used .... that's a bummer. It always scares me when I have to do things like this to brand new boards, especially when the blasted things are so tiny. .... any way to order the boards with the mod already done for those that know they will use this port???
What is the reason for this having to be done?
Do you, or will you have some pictures on your website of where this modification of moving the resistor takes place?
~ Craig ~
