ORIGINAL: frema
Well i can say i knew it along that jetcat is fooling with the egt probe
i measure it too
Like the iPhone 4 signal loss issue when holding it "wrong", update the firmware to always show full signal = problem solved
ORIGINAL: frema
ps, i tuned the juniors
2,3 kg is not bad heeee
Regards,
Martin.
Is this from stock engines just adjusted or did you fit the larger compressor to these too?
