ORIGINAL: wattsup
Thanks Brian, You are probably right and I appreciate your response. BTW, did you ever figure out the right set of props (make and size) for your CD? Everette
Hi Everette,
I'm flying a bipe with the contra.
So for me 22x18 front and 22x20 rear work best - Mikes carbon props.
With the bipe the higher pitch's give only a little extra speed but for much higher battery consumption - not a good trade off.
I am modifying some props but it will now be early Jan,, before I can do proper tests - busy with work right now untill and through xmass and need very calm weather for good tests.
Brian
Back to Adrians issue !
