RCU Forums - View Single Post - What refuelling pump setups do you use?
Old 12-10-2012 | 11:51 AM
smchale's Avatar
smchale
My Feedback: (67)
Default RE: What refuelling pump setups do you use?
ORIGINAL: husafreak
I am also interested as I get started into jets. I have read that Evo jet makes a fueling station with a variable flow rate, or you can use lower voltages, some even fill at a high rate and switch to a low rate for the satellite tanks. So I gather that you can damage your tanks or introduce unwanted air into the system if you fill at too high a rate. The Evo jet is not available in the states right now, or I haven't found it. I would ideally like to start with a variable rate pump.
I have one of the IQ-Hammer fill jugs with the variable rate fill dial. Works really nice. Added benefit is that it also houses my air pump. They even added my name and AMA number, [8D]. They weren't available in the US when I ordered it but I think Vogelsang now carries them.
