RE: Tadpoles
Some wheres in my parts bin is a "flywheel" the intended use was to add weight to balance the plane it replaces the front drive washer and front is recessed to get the prop nut on
and they are heavy can get in various weights 1 oz not uncommon might work to reduce vibration martin
way too big for the wee ones at least an inch in diameter 1/4 inch bore maybe 35s and up
