RE: NGH 38CC 4 stroke
Hi all,
I put the timing back to stock, 40ish degrees, and installed a 20-8 wood prop. I got it started after alot of choke and let it run at a fast idle for about 30-45 min.
The guy I got the engine from wanted me to run at least a full gallon through it before passing judgement on it. The eng. did seem to like the 20-8 wood better than the heavier carbon props I was trying earlier. After running for a bit, the carb did stop leaking. I'm going to just run the bujesus out of it on the stand to get it loosend up more. It didn't seem to run any different with the higher timing so I'll just leave it there. I do wish they would offer a muffler for it though.
By the way, where do we get parts if needed?
Mark.
