80 inch turbine powered Batwing-new pix on build
Had some trouble with the pic download -the pix are high res shotshad to do 2 at a time-anyway-shots of canopy back plate to stiffen it up -keeping to the theme I cut the image of the bat in itbattery location in nose section-light in wingworking on casting green lens for itshould look cool with the Batwing in a matte black finish and some accent air brushing-conformal tanks-5 liter cap total-radio tray under canopy the original model had plates on each side of the canopy so I made working hatches out of themthey will provide access for charging and start up without removing canopy.speed brakes as on the plastic model are almost finished-so far so goodP-180 should fit wellworking towards Toledo2013.
