RE: OS .46 la problems
If your Rossi really does have a tuned pipe it probably peaks closer to 15-16k rpm. So it will need a prop that lets it turn probably 14k on the ground to ever get into its power band. A colder plug may improve your top end power a bit. Hot plugs are usually for making an ornery engine idle and transition better or for making an engine with lower compression run well with no nitro fuel.
