RE: Noob here. LiPo battery charger??
Make a run by your local hobby shop and take your battery with you. They will have the correct connector for your battery. The Venom Pro Charger is a good bet to get for less than a $100. It will charge your LiPos, LiFe, Nicad, Nimh and lead acid. It will have all the connectors that you will need and it's a AC/CD charger. You can plug it into the wall or hook it to a car battery.
It also has a screen that will tell you what's going on with your battery.
Frank
