Just one caution? They're priced where they can be pretty addictive!
Here's a link to the one I have flying. You can get it as an ARF or as a "kit" where you pick out all your own electronics. That's the way I went, making a lot of mistakes with gear that's heavier than necessary - part of learning what's going on with these things. Pretty popular plane. Note it's 15% off for the next couple days....
The arf:
http://www.nitroplanes.com/02a-008-1...d-epp-arf.html
The kit
http://www.nitroplanes.com/02a-008-1...d-epp-kit.html
Kit also available at
http://www.hobbyking.com/hobbyking/s...m_EPP_ARF_.htm
Note also this plane has a wing loading and enough PRE INSTALLED carbon fiber that it does not require calm weather! PM regarding further suggestions. So far off topic with this, but thought there might be some interest here...
One last note and I'll quit. Landings can be quite interesting/different due to the TOTAL lack of momentum. You're used to pulling the power then gliding deep into the flare? Not the plan here. They just stop! Buy extra props! You'll need them getting used to that....
