RCU Forums - View Single Post - Dalotel Build
Old 12-12-2012 | 05:49 PM
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
Default RE: Dalotel Build
I found the time to do some laminating today. The fuse sides were masked with some scrap trim Monokote where I did not want epoxy. Then a thin layer of epoxy was spread out on some craft paper. The fuse side was layed on top of the epoxy and then carefully removed. The result was a thin film of epoxy on the fuse side and no epoxy where I didn't want it. The fin is 5/32 thick Nomex honeycomb with 1/16 basla skins and the firewall is a couple laminations of 3/32 ply. Last pic shows all the peices in the bag with peel ply top and bottom after vacuum is pulled. This will make for very strait parts.
ID:	1829376   Click image for larger version
ID:	1829377   Click image for larger version
ID:	1829378   Click image for larger version
ID:	1829379   Click image for larger version
