RCU Forums - View Single Post - engine mounting question
Old 09-12-2003 | 09:03 PM
Stick Jammer
Default RE: engine mounting question
Try pulling the engine out and bench run it upright for a few tanks to break it in. Once you are able to set the mixture for normal operation, invert it on the bench and run it. Be sure the fuel tank is at the same level in relation to the carb as it will be once it is back in the plane. Set the high and low needles on the bench and if it runs good there you should be good to go after it's reinstalled.
