RE: manuverable vs acrobatic
When fighters are doing the dance every movement causes drag that slows the plane. The Germans measured power by what AOA the craft could sustain. But in combat it most often translated into how much dancing you can do before you have to use altitude to bolster your Kinetic energy. When your opponent’s kinetic energy is low you have the option to break off or press the advantage.
Hope this helps
Joe
