RE: EME new engines, 35,60 & 120 twin
i hear you on the prop bolt pattern.i wish all engines had the same set up,the 60 has the same pattern as DLE,DA so that works for me.
also glad to hear that the engine is a true 60,thanks for the info.
i just half to say how much i like the Falcon 24-9 despite the lower rpm's,the engine is smoother the prop has a lot less noise.i think the plane is faster and has a fast vertical climb,pullouts are strong,good throttle response.
this is the first prop that i tried that gave me a lower rpm that i like better.
