RE: O.S. 46 FX on a pipe
Buy a new coupler and when you make length adjustments just leave enough space between the parts to avoid chafing. Remember that the engine takes "bong hits" off the return pulses as part of the magical cycle, so you don't want to feed it ground up aluminum paste.
Aluminum grit can coat the glow plug and foul it.
