RE: Illusion Build
Dave,
I got the smooth bellypan w/o the tunnel. I don't think I could modify the e-flight nose gear to fit. If I had used B&D's no problem. To be honest though, I never even thought of putting a pipe on this. I will when I do the EU-1A.
Now the fun part begins, cutting wood. I have all the plywood parts cut out. The wing hold down blocks are two layers of 1/4" oak epoxied together. The plans call for 1/4" plywood taped for 1/4-20. I think I will do the fuselage first setting the firewall, tailpost w/ fin tip and the hold downs.
