RCU Forums - View Single Post - 3 different Dual Rate at 2Point Switch
Old 12-16-2012 | 09:39 AM
davebart's Avatar
davebart
Default RE: 3 different Dual Rate at 2Point Switch
I have another question on this topic. I like all three surfaces on triple rates on the same switch. I have been setting this up as three different conditions but your FAQ says it can be done without setting conditions. I have tried to follow the FAQ and have failed. Maybe just failed to understand it. I get two rates but when I try to add the third, it does not work. It appears that I am unable to put Ail, Ele, and Rudd on the same three rate switch without setting up conditions.
