ORIGINAL: Arizona Flyer
ORIGINAL: taildragger21
we got in one of every engine to try as we are setting up
to sell them. the 120 i have has the same boltnpatten as a da 100. dle 111
Taildragger21 - Your EME 120 has the same bolt pattern as a DA 100? My EME 120 is NOT the same as my DA 100, the holes are spread further apart. I believe the EME 120 holes are the same as the DA 150. I recommend you double check this so you can be sure the information on your engines are correct.
Steve
Steve. Iwill double check again and confirm but I am pretty sure mine has the da100 pattern.
I just got 3 last week to evaluate direct from EME,, We are setting up as a dealer in the USA. I will make mention of this issue to the owner and let you guys know.
