ORIGINAL: Leonardo1982
Thanks a lot. Everything you say sounds very professional. I have a little problem with my remote control, sometimes stops working .... the servo only works left right nothing else!! and I need to turn off the switch from the ESC and turn on again to fix the problem .. i know i ask you too much things (sorry)
<div> </div>
thanx, I try to keep my advice professional. Im a redcat dealer, but like to think of myself as a avid hobbiest 1st. 7+ years of running RC's and being on the forums...ive learned alot. And too often, what Ive learned has come from owning cheaper...used models.
Your new radio issue is odd tho.
Is this with a new battery? Does the steering servo make any odd sounds? Turning only to the left normally would indicate the steering servo is partially stripped on the inside. But if it works fine every time you turn the model back on again then the issue must be somewhere else.
Im assuming that neither your ESC or reciever got wet, right?
On redcat's site, go to the "how to video" section. Under that section, find the link that says "radio guide"
There you will find a video showing how to "bind" your radio to your reciever. Sometimes, a radio/reciever can become messed up and re-binding them will fix that.
I once had my steering stop working...but rebinding the radio fixed it.
