RCU Forums - View Single Post - Illusion Build
Old 12-16-2012 | 12:25 PM
edp's Avatar
edp
Default RE: Illusion Build
The tail post and fin are in place. The engine/mount setup is done and ready for glassing to the fuselage. The engine is setup less the 90 degrees but not the 80 degrees called for in the plans. I didn't want to make a big cut out for the carb and ruin the look of the nose.
This will be a good spot to stop until the weekend. We have a big push at work before shutdown. Ho Ho Ho
ID:	1830837   Click image for larger version
