here it is now. very easy to do, took less than 30 minutes, and i just wonder, why did i not do this 10 flights ago. (dee dee dee moment)!![X(]
the white sleeves are stock, the red ones are slightly bigger OD and i drilled inside so that they telescope over the white ones by 20 mm, drilled new holes on more aft former, then glued them all in with 5 min epoxy. now, the servo movement is more in line with elevator movement, and much more responsive. up elevator requires pushrod to be pushed back, and this is where there is slight flex still, but way better than before.
