RCU Forums - View Single Post - Volcano epx pro Running problem
Old 12-17-2012 | 02:13 PM
nitrosportsandrunner's Avatar
Default RE: Volcano epx pro Running problem
ORIGINAL: Leonardo1982
So,, can be the ESC issue the problem of volcano? because sometimes the car run good without disconnect.. Im worried about that.. if the ESC is the problem can i change it?
not sure what you mean...
does the car work when you disconnect the steering servo? A bad steering servo can (tho its rare) effect the reciever and thus screw up throttle as well.
Any electronic parts are under warrenty. And if you want to go with a different ESC you can certainly do that. Any sensorless ESC will work with the stock motor.
Last, the volcano S30 alloy chassis would be very hard to use on the electric version. Whiile the diffs and suspension parts will bolt right on...the upper chassis/motor mount/battery mount and servo mount would all likely require drilling holes in the chassis. Even then, it would take some creativity.
You are the second or third person recently to ask that question....makes me want to pick up a volcano and buy the alloy chassis to see if I can do it[8D]
