RCU Forums - View Single Post - CMP Beaver conversion
Old 12-17-2012 | 04:18 PM
tomd-RCU
Default RE: CMP Beaver conversion
The open space was closed off using 1/16 plywood.
I used high temperature gasket material to seal the joint betwwen the firewall and the rest of the enclosure.
Because this enclosure covers the cowling supports, I made sure I drilled holes in the enclosure to access the T-nuts installed by the manufacturer.
