RE: Larger Revolver
Not if there's enough pitch on it?
You likely know this, but it's about total load, which is a combination of diameter AND pitch. You can increase or decrease either, and as long as you go the opposite way with the other, load will remain the same. What changes is efficiency. The smaller diameter will be more efficient at speed, the larger at slower speeds.
