RE: NEW Flyzone / Select Scale 48
I have had this plane for about a month now. Many flights. I post comments someplace here, but this plane is sweet. I also have the flyzone FW. The FW is a nice plane, the Corsair is a great plane, has more power and just plain fun to fly. I have flown it on both the FW 10x6x3 and a MA 11x5x3 prop. It flies and looks great with a three blade. The landing gear is pretty bulletproof. You do need to be careful about buying batteries. In order to get CG right the battery mounts crosswise in the nose. Any battery longer than 104/105mm will not fit. I use a 40c, Turnigy 2200mah 3s, works great. This is a very high class foamy stock right out of the box. I would not use the any link system though, several people at our field have had problems with them, buy the Rx Ready and use your own Rx and be happy.
PS: one thing I forgot to mention. Unless you are using a battery that is loose in the battery compartment do not put Velcro on it. All my batteries fit snugly and are near impossibly to get in and out with Velcro on them.
