RE: CMP Beaver conversion
Judgeing from past experience 3 degrees of down and 2 degrees of right sounds like way too much. Every conversion I have done to date needs some thrust taken out compared to what the electric setup had built in (and I use engines on the larger size for the plane). I would rather start either flush or with 1 and 1 and add washers as needed.
