RCU Forums - View Single Post - Census of Hotspots !!!
Old 12-20-2012 | 04:22 AM
  #72
1ricardo
My Feedback: (25)
Default RE: Census of Hotspots !!!
Hi All,
Hey Jessus since you are building a new one, here´s another thing that i used to build on my Hot spots.
I install a tab on the back of the airplane with arroud 30 degress, basicaly a straight line between the turbine case and the end of the fuselage at the root
What it does is allow me to take out the ALWAYS trim up on the stab, wiche´s a lot and with that the stab trim is flush with the wing, and once the trim is 0 the servo don´t need to hold the trim position during all flight and it save a lot of the battery and servo, also it allow the model to fly at a much lower speed once the aileron is zero ( wiche is good) instead of positive trim ( wiche is bad, once it change the airfoil shape) and reduce a lot the tip stalling a high alpha and i thing the airplane fly i little bit faster.
You may try, here´s some pics for you consideration
Ricardo
ID:	1832191   Click image for larger version
