ORIGINAL: Cougar-RCU
so going with a 17 or 18 X6 would be OK then as well with this new OS155FS in it? or should
I stay down on the size as well?
16/6 ?
The only problem you are probably going to have is clearance for the bigger size prop. If the 17 or 18 fit with no ground clearance problem then I say have at it. The only other problem is that on the specs it states that the prop range is 16x8-16x12 or 17x8-17x12(
that thing is going to haul butt with those props
) so if you put a 16x6 or 17x6 it might not be enough and the RPM's will probably be to high. I would say if you are going to do a 6 pitch then go with a 18x6, but there might be ground clearance issues.
Hope that helps.
