RCU Forums - View Single Post - Finishing sets for scale models
Old 12-20-2012 | 11:33 AM
mirce
Default RE: Finishing sets for scale models
Hello Whit, yes I have idea...
I can buy vinyl foils which is transparent, like glass, and of these foil I can made you all details. Because it's transparent, color from your surface will come trough rivets, lines and dummy screws...
When you make weathering dirt will stay around all details.
But, when you made panel lines first (before painting), you put panel lines on the surface apply filler and than take panel lines out from filler. In that case you get little channels - panel lines.
If you add vinyl lines after painting process, your panel lines will be above of the surface.
Vinyl lines and rivets are small, so I will proposed to put one layer of clear cote after you add details on model. That clear cote will add protective layer around these small details...
Regards
Mirce
