ORIGINAL: Horsepoweraviation
Forget the root rib...........thats not important........What is that tab doing under the 6th rib over!!??[X(][X(]
HPA
Well Paul, leave it to you [:-] to pick out my mistake........
I modified rib #7 which is located where the trailing edge joins together.......actually, I modified rib #6 by mistake - so it was too short to reach down to the trailing edge, so I had to put a little step in to facilate the rib/TE joint.......blah blah blah blah
The short answer is "It's there because I screwed up!"[X(]
