Oh My look what Hangar 9 has! 8KCAB Decathlon
Oh my. I couldn't believe my eyes. This may raise the bar for ARF's. it is a 100cc Bellanca Decathlon...
It is a Bit pricy, but still less than some of the jets Iv'e purchased.
Wingspan: 137.9 in (3504mm)
Overall Length: 96.0 in (2439mm)
Wing Area: 3177.0 sq. in. (205.0 sq. dm.)
Flying Weight: 38–42 lb (17.2–19.1 kg)
Engine Size: 80–120cc gas
Radio: 4-channel radio system (minimum)
Servos: (4) high-torque, (2) standard servos required
Recommended Receiver Battery: (2) 4000mAh
Trim Scheme Colors: UltraCote White (U870), True Red (U866), Black (U874)
CG (Center of Gravity): 6-1/2 to 7-1/8 in (165–181mm) back from the leading edge of wing
Prop Size: 24 x 10–27 x 10
Spinner Size: 4-1/2 in (114mm)
Flaps: No
Control Throw (Ailerons): Low: 19º up, 11.5º down, 25% expo; High: 26º up, 16.5º down, 30% expo
Control Throw (Elevator): Low: 15º up/down, 40% expo; High: 35º up/down, 45% expo
Control Throw (Rudder): 27º right/left, 35% expo
Main Wing Tube Length: 46.0 in (1168mm)
Main Wing Tube OD: 2.0 in (51mm)
Tail Wing Tube Length: 14.0 in (356mm)
Tail Wing Tube OD: 0.5 in (13mm)
Scale: 36%
Is Assembly Required: Yes
Plane Type: Scale Civilian
Experience Level: Advanced
Power Plant Size: 4.9-7.2 2-Cycle Gas
Recommended Environment: Outdoor
Fuel Type: Gas
