RCU Forums - View Single Post - Air Gauges
Thread: Air Gauges
Old 12-22-2012 | 04:38 PM
john4648
My Feedback: (24)
Default RE: Air Gauges
Don got the McMaster #38105K51 gauge so needs an adapter from std airline to a 1/8" NPT
Thanks for the help
John
Miniature Gauges
Use with air, water, hydraulic oil, ethyl alcohol, natural gas, and nitrogen
Pipe Connection: Brass NPT male or brass BSPT male
Accuracy: ±5% full scale (Grade D)
With a dial that’s less than an inch in diameter, these gauges work well in tight spots. Case is ABS plastic and lens is impact-resistant polycarbonate. Temperature range is -40° to 150° F.
Available Pressure Ranges (psi)
Pressure
Range Grad.
Marks Numeric
Increments
0-160 10 40
To Order: Please specify pressure range from the chart.
Center Back Connection
NPT Male
Dial Size Pipe Each
29/32" 1/8 38105K51 $9.92
