All,
I posted the info below a while back here:
http://www.rcuniverse.com/forum/m_91...m.htm#11304139
'Finishing up a new/old Bootlegger. I had one in 1979, won AMA Expert at the '79 Lincoln, NE NATS with it, see the attached 'old' pic... don't laugh at the kid... I stuck this airplane in the ground soon after this pic, the RX quit.
I came about this kit the same way as the one back in 1979, my dear friend Steve Helms gave me the kit this spring when I was at my son's heli contest in Huntsville. As you may suspect, this is a nostalgic and emotional project...
Since I really don't have anything to build airplanes with anymore (I use hammers and files on my helis!) I tracked down someone who I used to fly pattern with 'back in the day' to frame it up. So, Sam Leonard did a fantastic job framing it up and glassing the wood, making it ready for rigging and paint.
I've finished with the wing rigging, with retracts and ailerons hooked up and working. I'm going old school here, one servo with drilled output wheel for aileron differential if needed! Left to do is fuel tank, powerplant and pipe install and fuselage servo tray and rud/nose wheel, elev and throttle pushrods... then paint.
The model will be powered by a N.I.B. OPS F.I.R.E. 'Big Red' .60 and pipe (thanks Rusty!)! and I'm using Dave Brown Southern Pro retracts. Radio will be new stuff, Futaba 18MZ with 7 channel FASST RX and digital servos.
I'm shooting for test flight by the end of the year... see how that goes! I can't wait to hear the scream and go to a CPA/BPA contest in the SE.
Cliff Hiatt
