RCU Forums - View Single Post - Lightning Build
Old 12-23-2012 | 06:59 AM
  #434
Viper Driver's Avatar
Viper Driver
Default RE: Lightning Build
Panzi,
The key to minimizing weight in the the fuselage was mostly due to balsa wood selection. I ordered 25% more wood than I needed so I could select only the lightest. The difference between the lightest sheets and the heaviest sheets for the fuselage sides was about 60 g. I adds up quickly. If I recall correctly, my 36 inch by 4 inch by 1/8 sheets were between 19 and 21 grams.
Good luck with the build.
Jeff
