RCU Forums - View Single Post - "Hot Rod" Homelite 30cc
Old 12-23-2012 | 09:29 AM
1QwkSport2.5r's Avatar
1QwkSport2.5r
Default RE: RE:
ORIGINAL: av8tor1977
The narrow rings are good. Less friction and less ring flutter at high rpms.
You would be hard pressed to find a better deal than the one for sale in the market place. Even if you count your time at a buck an hour you would come out ahead. Just the custom two needle Walbro carb, the ignition sensor, the Twister Manifold, and the prop hub cost close to 100 bucks..... The whole engine with all the mods is only 150 as advertised....
AV8TOR
Don't want all the extra stuff. No spark ignition for me. Besides, $150 is a lot more than I want to spend on an experiment.
The boat guys chewed my tail for even asking about modifying a homelite. Waste of time they say. I disagree as he knowledge gained is worth the time to mess with it. Though I am taking on a build for another forum member that will put the homelite on the shelf for awhile anyway.
