RCU Forums - View Single Post - LED Flash and DBC question
Old 12-23-2012 | 03:13 PM
aceisback
Default RE: LED Flash and DBC question
Just an A123 sound board attached with the fire key connected to the fire sound pad on the board. Problem occurs with and with out the sound board connected. When I attach an LED to the flash output, the problem occurs, if I remove the LED all is fine. This occurs with both DBC boards. In my other tank, I can use the flash output as a trigger for my 555 timer flash circuit but not with an LED. That is what is making this strange. I will figure this out.
Are the flash led outputs tied directly to the PIC chip, or are they switched by the transistors on the board. I have not tried to analyze the circuit of the DBC board yet. If the LED is being driven by an output of the PIC chip, I wonder if I somehow damaged the chip during installation.
At this point I think it is either a power issue or an RX18 issue.
