RCU Forums - View Single Post - Eindecker EIII
Old 12-23-2012 | 04:01 PM
  #69
Tmoth4's Avatar
Tmoth4
Default RE: Eindecker EIII
ORIGINAL: R/C Art
ORIGINAL: Horsepoweraviation
Forget the root rib...........thats not important........What is that tab doing under the 6th rib over!!??[X(][X(]
HPA
Well Paul, leave it to you [:-] to pick out my mistake........
I modified rib #7 which is located where the trailing edge joins together.......actually, I modified rib #6 by mistake - so it was too short to reach down to the trailing edge, so I had to put a little step in to facilate the rib/TE joint.......blah blah blah blah
The short answer is ''It's there because I screwed up!''[X(]
Wow, is HPA anal! I had to go back and look close to see what he was talking about. You should start posting fuzzier pictures so he can't find your little mistakes!
Jim
