ORIGINAL: Anthoop
ORIGINAL: supertib
A carb is just like a airbrush...increase the airflow thru it and it will increase the volume of fuel is sprays.....a special injector is not needed here, the carb on its own works quite fine for handling ''boost ''....... If we double the volume of air passing thru the carb is will spray out double the volume of fuel it normally would............ this is fact of how a carb works........
Not really..no. The size of the jet will determine how much fuel/paint it can pass, the airflow provides the atomisation. More airflow requires more fuel/paint.
Nope Supertib is right, read this.
http://www.nitrorc.com/articles/carb/default.asp
